** Warning: (vlib-34) Library already exists at “work”.
QuestaSim vlog 10.0b Compiler 2011.05 May 5 2011
– Compiling module simpleadder
** Note: (vlog-2286) Using implicit +incdir+C:/questasim_10.0b/uvm-1.0p1/…/verilog_src/uvm-1.0p1/src from import uvm_pkg
– Compiling package sa_testbench_pkg
– Importing package mtiUvm.uvm_pkg (uvm-1.0p1 Built-in)
** Error: sa_sequence.svh(1): near “class”: syntax error, unexpected class, expecting ‘;’ or ‘,’
** Error: sa_sequence.svh(2): Undefined variable: sa_transaction.
** Error: sa_sequence.svh(2): (vlog-2294) The ‘var’ keyword is missing.
** Error: sa_sequence.svh(2): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER
** Error: C:/questasim_10.0b/win32/vlog failed.
Error in macro ./sa.do line 5
while executing
“vlog simple_adder.sv testbench.sv”
if i run the do file its showing above error. i not able to solve , please help me.
