Regarding assertion
I am making an environment in UVM to check the functionality of FIFO. In order to do this in driver class I have defined write and read tasks and also defined a variable called “count” as static. The purpose of this variable to track the size of the fifo and check it’s output signals fifo_ful and fifo_empty. For example if fifo size = 10 , then whenever write function is called count gets incremented by 1 and whenever read function is called count gets decremented by 1. Now I have defined two properties in interface like this :
fifo_driver drv_count;
property check_for_fifofull;
@(posedge WCLK) (drv_count.count == `FIFO_SIZE) |=> FIFO_FULL ;
endproperty
property check_for_fifoempty;
@(posedge RCLK) (drv_count.count == 0 ) |=> FIFO_EMPTY ;
endproperty
check_full : assert property (check_for_fifofull)
else
`uvm_error(“CHECK FOR FIFO FULL FAILED”,“fifo”)
check_empty : assert property (check_for_fifoempty)
else
`uvm_error(“CHECK FOR FIFO EMPTY FAILED”,“fifo”)
I am getting the following error while compilation.
Error-[ETTNATE] Invalid type in temporal expression
/proj/ams_ddrphy_funcv/users/maitri/lpddr4_24th_sep/verif/fifo/apb_interface.sv, 30
check_full, “drv_count.count”
Expressions involving real, string, event and dynamic SystemVerilog types
are not allowed in Boolean expressions in properties and sequences.
can I write an assertion like this ? Can I access the member of the class from property ?
Maitri
In reply to Maitri@07:
The question is which is
drv_count
Is it struct or is it a class?
fifo_driver is a driver class. drv_count is an object of this driver class.
If drv_count is a class object then you cannot write the assertion as you did. The error message points you to this situation:
‘Expressions involving real, string, event and dynamic SystemVerilog types
are not allowed in Boolean expressions in properties and sequences.’
A class type is a dynamic type.
As per this SVA in a UVM Class-based Environment | Verification Horizons | Verification Academy
. Assertions can also access static variables defined in classes; however, access to dynamic or rand variables is illegal.
I have defined count as static in the driver class.
Could you please show the code of class driver.
class fifo_driver extends uvm_driver # (amd_apb_transaction);
typedef virtual fifo_interface fifo_vif;
fifo_vif vif;
static int count = 0;
extern function new(string name = “fifo_driver”, uvm_component parent = null);
extern virtual function void connect_phase(uvm_phase phase);
extern virtual task run_phase(uvm_phase phase);
extern virtual protected task wclk_gen();
extern virtual protected task rclk_gen();
extern virtual protected task get_and_drive();
extern virtual protected task write(input bit [3:0] data);
extern virtual protected task read(output logic [3:0] data);
endclass: fifo_driver
task fifo_driver::run_phase(uvm_phase phase);
super.run_phase(phase);
this.get_and_drive();
this.wclk_gen();
this.rclk_gen();
join
endtask: run_phase
// ---------------------- clock generation ---------------------- //
task fifo_driver::wclk_gen();
bit clk;
this.pclk_en = 1;
this.vif.WCLK = 0;
if (this.pclk_en == 1)begin
#(PCLK_PERIOD/2); clk = ~clk; this.vif.WCLK = clk; end else begin uvm_info($sformatf(“%s:CLK_GEN”,get_name()), “STOPPING WPCLK”, UVM_LOW)
break;
endtask: wclk_gen
// ---------------------- DFI clock generation ---------------------- //
task fifo_driver::rclk_gen();
bit dficlk=0;
this.dficlk_en = 1;
this.vif.RCLK = 0;
if (this.dficlk_en == 1)begin
#(DFI_CLK_PERIOD/2); dficlk = ~dficlk; this.vif.RCLK = dficlk; end else begin uvm_info($sformatf(“%s:CLK_GEN”,get_name()), “STOPPING DFICLK”, UVM_LOW)
break;
endtask: rclk_gen
// ---------------------- get_and_drive ---------------------- //
task fifo_driver::get_and_drive();
`uvm_info($sformatf(“%s:get_and_drive”,get_name()), “STARTING get_and_drive”, UVM_LOW)
fifo_transaction tr;
seq_item_port.get_next_item(tr);
  case (tr.kind)
    fifo_transaction::read        : this.read( tr.rdata);
    fifo_transaction::write       : this.write(tr.wdata);
  endcase
join_any
disable fork;
seq_item_port.item_done();
end //forever begin
`uvm_info($sformatf(“%s:get_and_drive”,get_name()), “STOPPING get_and_drive”, UVM_LOW)
endtask: get_and_drive
// ---------------------- Read operation ---------------------- //
static task fifo_driver::read(output logic [3:0] data);
this.vif.RE = 1’b1;
@(posedge this.vif.RCLK);
if (count != 1’b0) begin
data = this.vif.PRDATA;
count = count - 1;
$display(“read count %d time %t”,count,$time);
else
$display(“count in else part %d time %t”,count,$time);
this.vif.RE = 1’b0;
endtask: read
//// ---------------------- Write operation ---------------------- //
static task fifo_driver::write(input bit [3:0] data);
this.vif.WE = 1’b1;
@(posedge this.vif.WCLK);
if (count <= `FIFO_SIZE) begin
this.vif.PWDATA = data;
count = count + 1;
$display(“write count %d time %t”,count,$time);
//this.vif.fifo_full = 1’b0;
else
$display(“count in else part %d”,count);
this.vif.WE = 1’b0;
endtask: write
Thanks for providing your code. It looks like you are facing a tool issue. I could compile your code with some minor modifications using Questa 10.6b.
Okay . Thanks you so much for your time. So my way of using the assertion is correct. Right ? I also wanted to ask you that in my code I am verifying for 1) write only
2) read only cases
Basically I am writing continuously for 10 times and then reading continuously . What if I want to do both the operations(wr/rd) simultaneously ? Do I need 2 agents ?
Sorry I have to correct me. The code does not contain the assertions.
Give me a few hours to look to the whole story.
  1. read only cases
The driver object in the interface where you are implementing the assertions makes your life complicated. I’d avoid such a combination, adding simply an additional signal count to the fifo_interface and assigning this in the driver object.
But the best solution would be to have all your properties/assertions in a seperate ‘assertion module’ you can connect to your testbenc or DUT using the bind construct.
WRT to your question about the numbers of agents. I assume your DUT is not able to write and to read at exactly the same time. What you are cuttently doing is running WR and RD in parallel using a fork/join. But this selects always 1 operation followed by the next one.
And here is the complete code, compiling in Questa without errors:
`include "uvm_macros.svh"
typedef class fifo_driver;
interface fifo_interface (input logic WCLK, input logic RCLK);
  logic PSEL, PENABLE, PWRITE;
  logic [15:0] PADDR;
  logic [31:0] PWDATA;
  logic [31:0] PRDATA;
  bit full;
@(posedge WCLK) (drv_count.count == 20) |=> full ;
endproperty
@(posedge RCLK) (drv_count.count == 0 ) |=> !full ;
endproperty
else
`uvm_error("CHECK FOR FIFO FULL FAILED","fifo")
else
`uvm_error("CHECK FOR FIFO EMPTY FAILED","fifo")
endinterface
class fifo_transaction extends uvm_object;
   int rdata;
   int wdata;
   enum {read, write}  kind;
class amd_apb_transaction extends uvm_object;
fifo_vif vif;
extern function new(string name = "fifo_driver", uvm_component parent = null);
//extern virtual function void connect_phase(uvm_phase phase);
this.wclk_gen();
this.rclk_gen();
join
endtask: run_phase
bit clk;
this.pclk_en = 1;
this.vif.WCLK = 0;
#50;
clk = ~clk;
else begin
`uvm_info($sformatf("%s:CLK_GEN",get_name()), "STOPPING WPCLK", UVM_LOW)
break;
endtask: wclk_gen
bit dficlk=0;
this.dficlk_en = 1;
this.vif.RCLK = 0;
#25;
dficlk = ~dficlk;
else begin
`uvm_info($sformatf("%s:CLK_GEN",get_name()), "STOPPING DFICLK", UVM_LOW)
break;
endtask: rclk_gen
function fifo_driver::new(string name = "fifo_driver", uvm_component parent = null);
`uvm_info($sformatf("%s:get_and_drive",get_name()), "STARTING get_and_drive", UVM_LOW)
case (tr.kind)
endcase
join_any
disable fork;
end //forever begin
`uvm_info($sformatf("%s:get_and_drive",get_name()), "STOPPING get_and_drive", UVM_LOW)
this.vif.RE = 1'b1;
if (count != 1'b0) begin
count = count - 1;
$display("read count %d time %t",count,$time);
else
$display("count in else part %d time %t",count,$time);
this.vif.RE = 1'b0;
endtask: read
this.vif.WE = 1'b1;
if (count <= 20) begin
count = count + 1;
$display("write count %d time %t",count,$time);
//this.vif.fifo_full = 1'b0;
else
$display("count in else part %d",count);
this.vif.WE = 1'b0;
endtask: write
Hi ,
I was trying to write the code for the scenario of simultaneous write and read . As per your suggestion I instantiated the same agent and added an extra uvm_sequence. So I have two uvm_sequence , one is driving on one agent which is having sequential write and read operations[writing 10 data and then reading them back] , second is driving on second agent which contains simultaneous write and read operations.
repeat(10) begin
uvm_do_with(req, {kind == amd_apb_transaction::write;}); uvm_do_with(req, {kind == amd_apb_transaction::read;});
join
In this manner what I am seeing in the waveform that it’s not doing write and read simultaneously. It’s writing first and then reading. Is my understanding correct here ? What can possibly go wrong here ?
logic [15:0] PADDR;
bit full;
endproperty
endproperty
else
else
endinterface
int rdata;
int wdata;
fifo_vif vif;
this.wclk_gen();
this.rclk_gen();
join
endtask: run_phase
bit clk;
this.pclk_en = 1;
this.vif.WCLK = 0;
#50;
clk = ~clk;
else begin
break;
endtask: wclk_gen
bit dficlk=0;
this.dficlk_en = 1;
this.vif.RCLK = 0;
#25;
dficlk = ~dficlk;
else begin
break;
endtask: rclk_gen
case (tr.kind)
endcase
join_any
disable fork;
end //forever begin
this.vif.RE = 1'b1;
count = count - 1;
else
this.vif.RE = 1'b0;
endtask: read
this.vif.WE = 1'b1;
count = count + 1;
else
this.vif.WE = 1'b0;
endtask: write
Here I am not using Qesta sim so I won’t be able to check with this method . I will have to use scoreboard only
I think I will have to use the virtual sequence here to control two sequences on two agents. let me try this and I will get back to you.
Hi ,
repeat(10) begin
join
If you are using fork/join you get interleaved accesses, staring randomly with 1 of your fork/join tasks.
Yes . Can you tell me how can I achieve simultaneous behavior ?
If you want to have 2 seperate tasks running in parallel you need 2 agents.
I am using 2 agents only. Like you suggested before ,I have instantiated the agent. One agent is writing and another agent is reading. In the test class in it’s run_phase I have run two sequences write and read on their respective agent’s sequencer.
task ddrphy_simple_read_write_test::run_phase(uvm_phase phase);
phase.raise_objection(this);
wr_h = write_seq::type_id::create(“wr_h”);
wr_h.start(env.write_agent.apb_sqr);
   rd_h = rd_seq::type_id::create("rd_h");
   rd_h.start(env.read_agent.apb_sqr);
   #50000;
   phase.drop_objection(this);
   //$finish;
How to make two agents work simultaneously ?
