Why should we generate clock in top module alone and not anywhere else like interface or some other blocks? What happens if I declare clock in some other block apart from top module.
module top;
//clock and reset signal declaration
bit clk;
bit reset;
//clock generation
always #5 clk = ~clk;
//reset Generation
reset = 1;
#5 reset =0;
//creatinng instance of interface, inorder to connect DUT and testcase
mem_if intf(clk,reset);
//DUT instance, interface signals are connected to the DUT ports
memory DUT (
.clk(intf.clk),
.reset(intf.reset),
.addr(intf.addr),
.wr_en(intf.wr_en),
.rd_en(intf.rd_en),
.wdata(intf.wdata),
.rdata(intf.rdata)
run_test();
