Hello
I have a memory PRAM and its been instantiated inside a reg_block SAY “XYZ” as “ram”. The XYZ reg_block has been instantiated inside a top_ral_block .
I have been trying to send a read command to the memory as shown below
m_rm.m_model.XYZ.ram.read(.status(status),.value(Data1),.parent(this));
//throws an error as
*E,FAABP2 Task/function call, or property/sequence instance does not specify all required formal arguments.
I have been using the same format for registers it has been working . Is there any other format to send the read/write to mem?
