Randomizing an array of transactions
I am a newbie with UVM/SV. I have a simple sequence_item with 2 random int variables. I am instantiating a dynamic array of the sequence_item in my sequence. Now I want to constrain the sequence_item in such a way that the random variables inside should not be the same. Below code gives run time Fatal error when it reaches the mentioned line. Solutions appreciated.
class my_transaction extends uvm_sequence_item;
rand int a;
rand int b;
– registered with factory and added field macros here –
class my_sequence extends uvm_sequence_item;
rand my_transaction items;
constraint c_txn {
items.size>0 && items.size<=10;
foreach(items[i]) {
items[i].ina != items[i].inb[1]; // FATAL ERROR on this line
Transcript of log:
ncsim: *E,RNDCNSTE (…/…my_seq_lib.sv,34|12): Randomization constraint has this error, which will cause the randomize function to return 0 and no new rand values will be set:
Null handle references in constraints are not supported.
if (!seq.do_not_randomize && !seq.randomize()) begin
ncsim: *W,SVRNDF (/tools/cadence/INCISIV14.10-s014/Linux/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh,1398|46): The randomize method call failed.
Observed simulation time : 0 FS + 99
UVM_FATAL /tools/cadence/INCISIV14.10-s014/Linux/tools/methodology/UVM/CDNS-1.1d/sv/src/seq/uvm_sequencer_base.svh(1400) @ 0: uvm_test_top.sa_env.sa_agent.sequencer [STRDEFSEQ] Randomization failed for default sequence ‘my_sequence’ for phase ‘main’
thanks
myashu
The randomize method will never construct class objects for you. You need to construct your array of items before calling randomize() or using the pre_randomize() method. The array needs to be as large as your constraints will allow, and the array size will get trimmed down to the size determined during randomization.
Thanks Dave,
Yes I need to add a pre_randomize() and create all the transactions in a foreach loop such that the number of created transactions are not less than the items.size() mentioned in the constraint block. I was able to contrain the variables of the transaction class with this.
thanks
Myashu
Can you help me with an example to implement an array of transactions?
In reply to Mohammed Essam Abd El Samee:
my_transaction tr[];
tr = new[5];
foreach(tr[ii]) begin
    tr[ii] = my_transaction::type_id::create("tr");
    if (!tr[ii].randomize) `uvm_error()
Thanks very much.
