Hello,
I have randomized the 2 dimensional dynamic array size by following code
rand logic address[][];
constraint c_address {
address.size() inside {[8:10]};
foreach(address[i]) {
address[i].size() inside {[8:10]};
I am able to constrain the size of array but, unable to constrain the range of the array i.e I want my address to be within range of 0-20.
I tried by further adding the constraint as
constraint d_address {
address[i] inside {[8:10]};
this is giving me an error : “(vlog-2728) Inside operator requires a singular type.”
Next I tried by adding
constraint range{foreach(address[i,j]) address[i][j] inside{[5:9]};}
then error : randomization is failing
I also used inline constrains in test
seq.randomize() with {address<=7} or seq.randomize() with {address[i]<=7}
for both of the above codes it gives an error: “Cannot mix packed and unpacked types in this operation”
can anyone please help me in sorting this out…
In reply to duggi bhavya:
The reason for your constraint failure is you declared a 2-D unpacked array of single bits.
Change your declaration to
rand logic [31:0] address[][];
Then your range constraint works.
Sorry for late response,
As u suggested the above format do works but, it doesn’t meet my requirement because by above code 2-d array each of 32 bit is being randomized but, I want randomize 2-d dynamic array each of one bit because I am using this in I2C_Protocol where single bit transmission should take place.
I want to constraint the address locations to verify each address location i.e if I want to send an 8 bit address i should be able give its range to be between 0-20 so eight bits should be in this range.
Think I am clear in framing in my doubt if there is any ambiguity please let me know,
Thank you.
I think you need to study the difference between packed an unpacked arrays and then maybe come up with a different approach to what you are doing.
