When I am randomizing it then it is throwing a fatal error.
Please guide me.
Thanks in advance.
class ahb_seq_item extends uvm_sequence_item;
// global signal
rand bit HRESETn;
// address and control signals
bit [31:0] HADDR[];
rand brust_type HBURST;
rand size_type HSIZE;
rand transfer_type HTRANS;
rand rw_en HWRITE;
// data signals
rand bit [31:0] HWDATA[];
bit [31:0] HRDATA;
// transfer response
resp_type HRESP;
bit HREADY;
rand bit [11:0] start_add;
constraint start_con { start_add inside {[10:30]};}
`uvm_object_utils_begin(ahb_seq_item)
`uvm_field_int(HRESETn, UVM_ALL_ON)
`uvm_field_array_int(HADDR, UVM_ALL_ON)
`uvm_field_enum(brust_type, HBURST, UVM_ALL_ON)
`uvm_field_enum(size_type, HSIZE, UVM_ALL_ON)
`uvm_field_enum(transfer_type, HTRANS, UVM_ALL_ON)
`uvm_field_enum(resp_type, HRESP, UVM_ALL_ON)
`uvm_field_enum(rw_en, HWRITE, UVM_ALL_ON)
`uvm_field_array_int(HWDATA, UVM_ALL_ON)
`uvm_field_int(start_add, UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="ahb_seq_item");
HRESETn = 1;
endfunction: new
//----constraints for storing incr and wrap brust type in a varaible
brust_type str_incr ;
brust_type str_wrap;
constraint incr_name { if (HBURST == INCR4) str_incr == INCR4;
if (HBURST == INCR8) str_incr == INCR8;
if (HBURST == INCR16) str_incr == INCR16;
if (HBURST == WRAP4) str_wrap == WRAP4;
if (HBURST == WRAP8) str_wrap == WRAP8;
if (HBURST == WRAP16) str_wrap == WRAP16;
//----Constraints for finding hsize length for incrementing the address
int hsize_in_byte;
constraint addr_size {
if(HSIZE == BYTE) hsize_in_byte == 1;
if(HSIZE == HALFWORD) hsize_in_byte == 2;
if(HSIZE == WORD) hsize_in_byte == 4;
if(HSIZE == WORDx2) hsize_in_byte == 8;
if(HSIZE == WORDx4) hsize_in_byte == 16;
if(HSIZE == WORDx8) hsize_in_byte == 32;
if(HSIZE == WORDx16) hsize_in_byte == 64;
if(HSIZE == WORDx32) hsize_in_byte == 128;
//---- constraints for finding length burst length---------------------
rand bit [11:0] undefined_length;
constraint brust_length_con {
if(HBURST==SINGLE) { HADDR.size == 1; HWDATA.size == 4; }
if(HBURST==INCR) {
HWDATA.size == undefined_length;
HADDR.size == undefined_length;
undefined_length > 0 ;
undefined_length < 1024; }
if(HBURST==WRAP4 || HBURST==INCR4) { HADDR.size == 4; HWDATA.size == 4; }
if(HBURST==WRAP8 || HBURST==INCR8) { HADDR.size == 8; HWDATA.size == 8; }
if(HBURST==WRAP16 || HBURST==INCR16) { HADDR.size == 16; HWDATA.size == 16; }
//------Wrap address calculation --------------------------------------
bit [31:0] end_addr;
int total_bytes;
bit [31:0] wrap_bound;
bit [4:0] haddr_size;
constraint wrap_cal {
if (HADDR.size == 4 || HADDR.size == 8 || HADDR.size == 16){
haddr_size == (HADDR.size) ;
total_bytes == hsize_in_byte*haddr_size;
wrap_bound == int'(start_add / total_bytes)* total_bytes ;
end_addr == wrap_bound + total_bytes ;
//WRAP4 or WRAP8 or WRAP16
if (HBURST == str_wrap){
foreach(HADDR[i]){
if(i ==0) { HADDR[i] == start_add ; }
else {
if( HADDR[i] == end_addr){ HADDR[i]== wrap_bound ; }
else{ HADDR[i] == HADDR[i-1] + hsize_in_byte ; }
//-------address boundary calc for SINGLE, INCR, INCR4, INCR8 n INCR16
constraint address_boundary {
if (HBURST == SINGLE) {foreach(HADDR[i]) HADDR[i] == start_add; }
if (HBURST == INCR){
foreach(HADDR[i]){
else { HADDR[i] == HADDR[i-1] + hsize_in_byte ; }
//INCR4 or INCR8 or INCR16
if (HBURST == str_incr){
foreach(HADDR[i]){
if(i ==0) {HADDR[i] == start_add ;}
endclass : ahb_seq_item
class ahb_single_seq extends ahb_base_seq;
`uvm_object_utils(ahb_single_seq)
function new(string name="ahb_single_seq");
endfunction:new
task body();
ahb_seq_item seq = ahb_seq_item::type_id::create("seq");
start_item(seq);
if(!seq.randomize())
`uvm_fatal("SINGLE SEQ","randomziation failed inside sequence")
seq.print();
seq.HRESETn = 1 ;
finish_item(seq);
endtask : body
endclass: ahb_single_seq
