Dear Verification Academy Team,
I m trying to setup complex address mapping in the RAL model. I want to connect same register model to the individual AXI write and
AXI read sequencer. I have created 2 address maps and used add_submap to add register block to the 2 address maps. Somehow it is
not working. For your better understanding i have added snippet code for you.
//************** Code in the regmodel******************
rand ral_block_mss_regs mss_regs;
// Register maps for write and read
uvm_reg_map axi_wr_map;
uvm_reg_map axi_rd_map;
// Creating write address map
this.axi_wr_map = create_map("axi_wr_map", 0, 4, UVM_LITTLE_ENDIAN, 0);
this.mss_regs = ral_block_mss_regs::type_id::create("mss_regs",,get_full_name());
this.mss_regs.configure(this, "");
this.mss_regs.build();
this.axi_wr_map.add_submap(this.mss_regs.default_map, `UVM_REG_ADDR_WIDTH'h2000000);
// Creating read address map
this.axi_rd_map = create_map("axi_rd_map", 0, 4, UVM_LITTLE_ENDIAN, 0);
this.axi_rd_map.add_submap(this.mss_regs.default_map, `UVM_REG_ADDR_WIDTH'h2000000);
//***************** Code in the environment top****************
// Setting AXI write sequencer to the register map
regmodel.axi_wr_map.set_sequencer( .sequencer(m_axi_env.q_master_agent[15].m_write_sequencer), .adapter(reg_adapter_h) );
// Setting AXI read sequencer to the register map
regmodel.axi_rd_map.set_sequencer( .sequencer(m_axi_env.q_master_agent[15].m_read_sequencer), .adapter(reg_adapter_h) );
// Setting auto predictor
regmodel.axi_wr_map.set_auto_predict(1);
regmodel.axi_rd_map.set_auto_predict(1);
//***************** Test case********************
e.regmodel.mss_regs.cfg_tgen_cfg14.write(reg_status, 'h5a5b5c5d, .map(axi_wr_map));
e.regmodel.mss_regs.cfg_tgen_cfg14.read(reg_status, reg_data, .map(axi_rd_map));
Error reported:
reporter [RegModel] Map ‘regmodel.mss_regs.uvm_reg_map’ is already a child of map ‘regmodel.axi_wr_map’. Cannot also be a child
of map ‘regmodel.axi_rd_map’
Madhu
