Hi all.
This one has me going in circles. I’ve found related info in this forum but still can get it to work.
I have a top-level testbench with a bunch of parameters used to configure the RTL DUT and can also be overridden in the command-line with -g PNAME=PVALUE (I’m using QuestaSim).
I need to use these parameters in various places in my UVM env. From another post, I found this which partially works:
top.sv
module top;
parameter A;
my_uvm_config cfg_h; // config object to store parameters
start_of_simulation_ph.wait_for_state(UVM_PHASE_STARTED); // make sure to wait until UVM objects created
uvm_config_db # (my_uvm_config) :: get (null, "", "my_uvm_config", cfg_h);
cfg_h.a = A;
my_uvm_config.sv:
class my_uvm_config extends uvm_object;
`uvm_object_utils(my_uvm_config)
int unsigned a;
// new, etc
basetest.sv:
class basetest extends uvm_test;
function void build_phase (phase);
cfg_h = my_uvm_config :: type_id :: create ("cfg_h", this);
uvm_config_db # (my_uvm_config) :: set (null, "*", "my_uvm_config", cfg_h);
cfg_h.a = 5; // default value
Now this seems to work ok. Where it all breaks is that I have some agents set up in the env containing basetest that also need to get access to the value ‘a’ that might have been overridden in the command-line. When I set up a similar config object for the agent and try and set it in top, it doesn’t seem to wait for the UVM_PHASE_STARTED or some kind of race and the agents just get the default value.
I tried messing with uvm_config_db::wait_modified but couldn’t get the syntax right and couldn’t find much documentation for it (or start_of_simulation_ph.wait_for_state). Any ideas? Any better ways of passing RTL parameters into UVM land?
David
