We are trying to verify APB protocol with a master and a single slave and with configuration, we are able to print topology fine.
But with driver and monitor logic, we are not able to drive signals to DUT.
Only changes made to the code after printing topology with config are:
Connect Phase and Run phase in Driver.
Started sequence in test(sequencer within the env).
Thank you for the support cgales.
EDA playground and the waveform viewing method was new for me.
However I’ve fixed it now.
Thanks a million for your help.
