Hi ,
I have a few questions on the typical code written in body() of user_sequence
[ A ] Randomizing Request Item
// In body() of user_sequence
req = user_seq_item :: type_id :: create( "req" ) ;
start_item( req ) ;
// [Q1] Request Item is recommended to be randomized here , why ??
finish_item( req ) ;
One scenario I see is constraint is based on some properties ( sequencer properties , TB Current Condition etc )
So when start_item() unblocks the properties would have latest values hence it makes sense to randomize() here .
[ B ] Consuming Time between start_item() N finish_item()
" finish_item must be called after start_item with no delays or delta-cycles.
Although pre_do is a task, consuming simulation cycles may result in
unexpected behavior on the driver. "
// Why unexpected behavior on driver ??
[Q2] Why is it so ?
Is there a Error if blocking statement / delay is added between
start_item() N finish)_item() OR consuming Time via task pre_do() is added
**EDIT ::** Refer [try_next_item_protocol_check](https://verificationacademy.com/forums/uvm/uvmerror-only-trynextitem) where we Observe that task **' try_next_item ' has checks to ensure there is No delay ( apart from 1 NB ) between call to start_item( req ) N finish_item( req )** !!
