Hi Dave,
I am not able to attach the uvm_cook book version i have. I have copy-pasted the code from my version of uvm cookbook.
I have put a comment “I am referring to this line” just above the line of the code I am referring to. Please let me know if there is some issue with code. (could be a typo also)
Anyways I will be using the latest version of uvm cook book now.
// Class Description:
class pss_test_base extends uvm_test;
// UVM Factory Registration Macro
`uvm_component_utils(pss_test_base)
// Data Members
// Component Members
// The environment class pss_env m_env;
// Configuration objects pss_env_config m_env_cfg; spi_env_config m_spi_env_cfg; gpio_env_config m_gpio_env_cfg;
//uart_env_config m_uart_env_cfg; apb_agent_config m_spi_apb_agent_cfg; apb_agent_config m_gpio_apb_agent_cfg; ahb_agent_config m_ahb_agent_cfg; spi_agent_config m_spi_agent_cfg; gpio_agent_config m_GPO_agent_cfg; gpio_agent_config m_GPI_agent_cfg; gpio_agent_config m_GPOE_agent_cfg;
// Register map
pss_register_map pss_rm;
// Methods
// Standard UVM Methods:
extern function new(string name = "spi_test_base", uvm_component parent = null);
extern function void build_phase( uvm_phase phase);
extern virtual function void configure_apb_agent(apb_agent_config cfg, int index, logic[31:0] start_address, logic[31:0] range);
extern task run_phase( uvm_phase phase );
endclass: pss_test_base
function pss_test_base::new(string name = "spi_test_base", uvm_component parent = null); super.new(name, parent);
// Build the env, create the env configuration
// including any sub configurations and assigning virtural interfaces
function void pss_test_base::build_phase( uvm_phase );
m_env_cfg = pss_env_config::type_id::create("m_env_cfg");
// Register map - Keep reg_map a generic name for vertical reuse reasons pss_rm = new("reg_map", null);
m_env_cfg.pss_rm = pss_rm;
// SPI Sub-env configuration:
m_spi_env_cfg = spi_env_config::type_id::create("m_spi_env_cfg"); m_spi_env_cfg.spi_rm = pss_rm;
// apb agent in the SPI env:
m_spi_env_cfg.has_apb_agent = 1;
m_spi_apb_agent_cfg = apb_agent_config::type_id::create("m_spi_apb_agent_cfg"); configure_apb_agent(m_spi_apb_agent_cfg, 0, 32'h0, 32'h18);
if( !uvm_config_db #(virtual apb_if)::get(this, "","APB_vif",m_spi_apb_agent_cfg.APB) ) `uvm_error(...) m_spi_env_cfg.m_apb_agent_cfg = m_spi_apb_agent_cfg;
// SPI agent:
m_spi_agent_cfg = spi_agent_config::type_id::create("m_spi_agent_cfg");
if( !uvm_config_db #(virtual spi_if)::get(this, "" , "SPI_vif",m_spi_agent_cfg.SPI) ) `uvm_error(...) m_spi_env_cfg.m_spi_agent_cfg = m_spi_agent_cfg;
m_env_cfg.m_spi_env_cfg = m_spi_env_cfg;
//I am referring to this line below
if( !uvm_config_db #( spi_env_config )::set("*", "", "spi_env_config", m_spi_env_cfg) ) `uvm_error(...)
// GPIO env configuration:
m_gpio_env_cfg = gpio_env_config::type_id::create("m_gpio_env_cfg"); m_gpio_env_cfg.gpio_rm = pss_rm;
m_gpio_env_cfg.has_apb_agent = 1; // APB agent used
m_gpio_apb_agent_cfg = apb_agent_config::type_id::create("m_gpio_apb_agent_cfg"); configure_apb_agent(m_gpio_apb_agent_cfg, 1, 32'h100, 32'h124);
if( !uvm_config_db #(virtual apb_if)::get(this, "" , "APB_vif",m_gpio_apb_agent_cfg.APB) ) `uvm_error(...) m_gpio_env_cfg.m_apb_agent_cfg = m_gpio_apb_agent_cfg;
m_gpio_env_cfg.has_functional_coverage = 1; // Register coverage no longer valid
// GPO agent
m_GPO_agent_cfg = gpio_agent_config::type_id::create("m_GPO_agent_cfg"); uvm_config_db #(virtual gpio_if)::get(this, "GPO_vif",m_GPO_agent_cfg.GPIO); m_GPO_agent_cfg.active = UVM_PASSIVE; // Only monitors m_gpio_env_cfg.m_GPO_agent_cfg = m_GPO_agent_cfg;
// GPOE agent
m_GPOE_agent_cfg = gpio_agent_config::type_id::create("m_GPOE_agent_cfg"); uvm_config_db #(virtual gpio_if)::get(this, "GPOE_vif",m_GPOE_agent_cfg.GPIO); m_GPOE_agent_cfg.active = UVM_PASSIVE; // Only monitors m_gpio_env_cfg.m_GPOE_agent_cfg = m_GPOE_agent_cfg;
// GPI agent - active (default)
m_GPI_agent_cfg = gpio_agent_config::type_id::create("m_GPI_agent_cfg");
if( !uvm_config_db #(virtual gpio_if)::get(this, "" , "GPI_vif",m_GPI_agent_cfg.GPIO) ) `uvm_error(...) m_gpio_env_cfg.m_GPI_agent_cfg = m_GPI_agent_cfg;
// GPIO Aux agent not present m_gpio_env_cfg.has_AUX_agent = 0;
m_gpio_env_cfg.has_virtual_sequencer = 0;
m_gpio_env_cfg.has_reg_scoreboard = 0;
m_gpio_env_cfg.has_out_scoreboard = 1;
m_gpio_env_cfg.has_in_scoreboard = 1; m_env_cfg.m_gpio_env_cfg = m_gpio_env_cfg;
uvm_config_db #( gpio_env_config )::set( this , "*", "gpio_env_config", m_gpio_env_cfg);
// AHB Agent
m_ahb_agent_cfg = ahb_agent_config::type_id::create("m_ahb_agent_cfg");
if( !uvm_config_db #(virtual ahb_if)::get(this, "", "AHB_vif",m_ahb_agent_cfg.AHB) ) `uvm_error(...) m_env_cfg.m_ahb_agent_cfg = m_ahb_agent_cfg;
// Add in interrupt line
if( !uvm_config_db #(virtual icpit_if)::get(this, "", "ICPIT_vif",m_env_cfg.ICPIT) ) `uvm_error(...) uvm_config_db::set( this , "*", "pss_env_config", m_env_cfg);
m_env = pss_env::type_id::create("m_env", this);
// Override for register adapters: register_adapter_base::type_id::set_inst_override(ahb_register_adapter::get_type(), "spi_bus.adapter"); register_adapter_base::type_id::set_inst_override(ahb_register_adapter::get_type(), "gpio_bus.adapter");
endfunction: build_phase
// Convenience function to configure the apb agent
thanks,
-sunil
