Hi everyone,
I have a question about reg_predictor.
In my environment, I have connected predictor bus_in port to output analysis port of monitor. I have also implement reg_adapter bus2reg function and connect adapter to predictor. I’m using passive prediction (Registers/Integrating | Verification Academy). The mirror value of uvm_reg should be updated as long as there’s transaction sent from monitor. However I did not see that happen. When I check the source code for uvm_reg_predictor, it seems like it failed in get_reg_by_offset() function so that it did not get uvm_reg object. Did anyone has similar issue? If so, what’s your solution? Thanks.
