Hello expert
I am a new guy for questasim, I want to use questasim to build UVM project, but I do not how to import UVM library,
I write 'include “uvm_pkg.sv” at the begin of .sv file, and I compile it, but I got a error message
** Error: (vlog-13053) D:/questasim/examples/test.sv(2): near “'i”: Illegal base specifier in numeric constant.
** Error: (vlog-13069) D:/questasim/examples/test.sv(2): near “'i”: syntax error, unexpected BASE, expecting class.
can you tell me why? and give me a manual for questasim?
Best Regards
Jack
In reply to JackShan:
You are getting syntax errors that are not likely anything to do with the particular tool you are using. You need to show us line 2 of test.sv and the lines before it.
And you want to import the uvm_pkg, not `include it. You might want to read http://go.mentor.com/package-import-versus-include
infect,I just write one sentence until now
'include "uvm_pkg.sv"
until now, I just write very simple SystemVerilog sentence:
`include "uvm_pkg.sv"
module hello_world_example;
`include "uvm_macros.svh"
`uvm_info("info1","Hello UVM!",UVM_LOW)
endmodule: hello_world_example
and I compile the code, then I got four errors
vlog -work work -vopt -sv -stats=none D:/questasim/examples/test.sv
QuestaSim-64 vlog 10.6c Compiler 2017.07 Jul 26 2017
** Error: D:/questasim/examples/test.sv(1): Cannot open include file "D:/questasim/ovm-2.1.2/../verilog_src/ovm-2.1.2/src/uvm_pkg.sv". -- Compiling module hello_world_example -- Importing package uvm_pkg (uvm-1.1d Built-in) ** Error: D:/questasim/examples/test.sv(4): Cannot open
include file “D:/questasim/ovm-2.1.2/…/verilog_src/ovm-2.1.2/src/uvm_macros.svh”.
** Error: D:/questasim/examples/test.sv(6): (vlog-2163) Macro `uvm_info is undefined.
** Error: (vlog-13069) D:/questasim/examples/test.sv(6): near “(”: syntax error, unexpected ‘(’.
This related to your simulation/computer setup.
The path
points to OVM and not UVM.
Please correct this and it will work.
hello chr_sue
where can I modify the path? because I did not find setup in simulation column.
Best regards
Jack
You can set this with the environment variable UVM_HOME or you can modify your modelsim.ini file by setting
mtiUvm = $MODEL_TECH/…/uvm-1.1d or
mtiUvm = $MODEL_TECH/…/uvm-1.2
depending on which UVM version you want to run.
I find following setting in file modelsim.ini
; ieee = $MODEL_TECH/../vital1995
; For compatiblity with previous releases, logical library name vital2000 maps
; to library vital2000 (a different library than library ieee, containing the
; same packages).
; A design should not reference VITAL from both the ieee library and the
; vital2000 library because the vital packages are effectively different.
; A design that references both the ieee and vital2000 libraries must have
; both logical names ieee and vital2000 mapped to the same library, either of
; these:
; $MODEL_TECH/../ieee
; $MODEL_TECH/../vital2000
verilog = $MODEL_TECH/../verilog
std_developerskit = $MODEL_TECH/../std_developerskit
synopsys = $MODEL_TECH/../synopsys
modelsim_lib = $MODEL_TECH/../modelsim_lib
sv_std = $MODEL_TECH/../sv_std
mtiAvm = $MODEL_TECH/../avm
mtiRnm = $MODEL_TECH/../rnm
mtiOvm = $MODEL_TECH/../ovm-2.1.2
mtiUvm = $MODEL_TECH/../uvm-1.1d
mtiUPF = $MODEL_TECH/../upf_lib
mtiPA = $MODEL_TECH/../pa_lib
floatfixlib = $MODEL_TECH/../floatfixlib
mc2_lib = $MODEL_TECH/../mc2_lib
osvvm = $MODEL_TECH/../osvvm
So I just delete the sentence
it seems not ok, should I modified another place?
regards
What you see you should not modify.
The tool discussion is not allowed here in the public domain.
Please respond on my email:
christoph@christoph-suehnel.de
