Hi All,
I am facing a strange error when using TLM fifo,put and get port. I am not able to get the item through get port which was put to put port.
Code is similar like code below.
class one;
uvm_put_port #(item1) put_port;
uvm_tlm_fifo #(item1) fifo_h;
function build_phase();
put_port =new("put_port",this);
fifo_h = new("fifo_port",this);
function connect_phase();
put_port.connect(fifo_h.put_export);
class two;
uvm_get_port #(item1) get_port;
get_port = new("get_port",this);
class env;
one o1;
two t2;
function connnect_phase();
t2.get_port.connect(o1.fifo_h.get_peek_export);
Class seq;
item i1;
task send item();
p_sequencer.o1.put_port(i1);
class seq2;
task collect_item;
// DISPLAY STATEMENTS ARE PRINTED HERE
p_sequencer.t2.get_port(i1); // NOT ABLE TO GET THE ITEM.
Now I have used few debugs. Like i tried to monitor both fifo and get port using print statements in env class.
Like when i used following function to monitor
`uvm_info (“DEBUG”, " Fifo port size:%d", Try_get:%d", o1.fifo_h.used, t2.try_get(item1)),UVM_LOW)
I got following prints in below fashion
1st print Fifo_port size: 1, Try_get : 1
2nd print Fifo_port size: 0, Try get : 0
3rd print Fifo_port size: 0, Try get : 0
Now if i use following function to monitor.
`uvm_info (“DEBUG”, " Fifo port size:%d", Can_get:%d", o1.fifo_h.used, t2.can_get()),UVM_LOW)
I get print in following manner.
1st print Fifo_port size: 1, Can_get : 0
2nd print Fifo_port size: 1, Cry get : 0
3rd print Fifo_port size: 1, Cry get : 0
Please let me know why “try_get” can access the get port and get the item.
Why “can_get” and “get” cannot access or get the item.
Please help me in solving this issue.
