Hi All,
can we use p_sequencer inside the transaction class ??
thanks and regards,
vinay
Hi All,
thanks and regards,
vinay
In reply to kumar-vin:
You should never need to use p_sequencer as this makes re-use of sequences very limited.
Instead, you should put the handles to the sequencers in the virtual sequence, and use m_sequencer as a reference to the sequencer that the sequence is running on.
