Printing in UVM
From end_of_elaboration_phase() of Test if I write ::
( 1 )
  this.print() ;
         **V / S**
( 2 )
  uvm_top.print_topology() ;
[ I ] Would there be a difference in Output Observed ?
[ II ] Also class uvm_factory has a function :: print()
     So  this  should  be  used  with  **argument  0**  i.e
factory.print( 0 ) ;
     to  observe  any  type  N  instance  override  registered in  factory  right ?
[ III ] While going the UVM library ( UVM 1.1d ) I Observe ::
           const uvm_factory factory = uvm_factory::get(); //  Global  Singleton instance hence  can  be  accessed from  anywhere in TB
    However in  UVM 1.2  I  don't  observe  a  similar  global  instance
    as  factory is  an  abstract class  .  Is  there  a  reason  for  this  ?
In reply to Have_A_Doubt:
  1. print() is method of the base class uvm_object. It prints the string name and the string type name of the object along with anything else the extend class has set up to print. print_topology is a method of uvm_root only. It is a debugging method.
  2. The print() method of uvm_factory is set up tp print debug information. Providing argument 0 list all the overrides.
  3. UVM 1.2 began the process of eliminating direct access to global variables, which is generally consider a bad programing practice. Direct access has problems with time 0 initialization race conditions.
Hi Dave ,
A few follow up questions
(1) I understand that print and print_topology are functions of different classes .
From Test i.e “uvm_test_top” via both this.print() and uvm_top.print_topology() ,
I observe same output i.e TB Structure .
However from user_env , this.print() would display hierarchy from env and the hierarchy below env
( i.e agent and it’s sub-components i.e driver and sequencer ) whereas
uvm_top.print_topology()would still show the entire TB hierarchy from uvm_test_top
So essentially ::
(a) print function inherited from uvm_object shows the TB hierarchy
from below that component and it’s sub - components .
(b)
uvm_top.print_topology() shows the entire TB hierarchy irrespective from where it’s called
From body() of user_sequence via this.print() the output is different ::
Name                           Type           Size  Value
seq_h                          user_seq       -     @637
  begin_time                   time           64    0
  depth                        int            32    'd1
  parent sequence (name)       string         0     ""
  parent sequence (full name)  string         0     ""
  sequencer                    string         23    uvm_test_top.env_h.seqr
  req                          user_seq_item  -     @642
  rsp                          rsp_ext_item   -     @646
( 2 ) Could you please elaborate on
       "Direct access has problems with time 0 initialization race conditions."
I  understand  that  static  property  initialization  is  undefined  in  LRM .
To  ensure  that  there  exists  a  Singleton  instance  of  factory ,  user  needs  to
call  factory  static  function  get .
So  doesn't  this  eliminate  the  time 0 race  conditions ?
Hello Dave with respections, how do we do print_topology() in UVM 1.2? I actually get this issue now.
In reply to yangshougui:
uvm_root r;
r = uvm_root::get();
r.print_topology();
