Is it possible to set phase_timeout for individual sub phases within run_phase?
If yes, what is the recommended way to implement this?
Thanks!
Thanks!
In reply to SV_UVM_Baby:
The UVM’s timeout is just a big red button to hit if your simulation takes up too much time.
We don’t recommend using sub-phases, but if you do, you could call set_timout() at the beginning of each phase to reset the timer.
Thanks for the response Dave.
Is there any reason / thread which I can refer, which would help me to understand why sub-phases aren’t recommended?
The reason is you can never count on everyone using the same phases constantly. Use sequences.
