PHASE OBJECTION
Hi ,
Can anyone please explain me about when the phase.drop_objection should be dropped.
In the testcase ,
phase.raise_objection();
sequence.start(sequencer);
phase.drop_objection();
The sequencer is started and transaction initiated.when all the transaction completed from sequence side ,the objection is dropped right.?
so , here Scoreboard doing some kind of analysis to the last transaction that may include some time-consuming behavior.
what if the objection the dropped in last transaction.? how to overcome this and what is the solution to overcome this.?
Sandeep Gaur
In reply to Sandeep Gaur:
Use set_drain_time() to allow some component to complete its task(last transaction handling).
In reply to HanAnatoli:
Hi HanAnatoli ,
But giving delay is not the right method to handle the situation right.
Delay changes for every testcases based on transaction completion time.
Sandeep Gaur R
Hi,Sandeep Gaur
Refer to : Redirecting…
Regards,
Anatoli
Hi Anatoli,
Thanks for the link. It is easy to understand and useful.
Sandeep Gaur R
