Hi all ,
I am trying out code to pass configuration from env to Top-Level Components : uvm_test_top and its sibling
From low-level Component we pass resource to 2 Top-Level Components ::
uvm_test_top N Component instantiated before call to run_test() !!
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
`define COMP_NEW function new ( string name , uvm_component parent ) ; \
super.new(name,parent);\
`define OBJ_NEW function new ( string name = "" ) ; \
super.new(name);\
class user_config extends uvm_object ;
`uvm_object_utils(user_config)
`OBJ_NEW
bit has_comp ;
bit has_test ;
class user_env extends uvm_env ;
`uvm_component_utils(user_env)
`COMP_NEW
user_config config_h ;
task main_phase ( uvm_phase phase ) ;
phase.raise_objection(this);
config_h = new("config_h");
config_h.has_comp = 1 ;
config_h.has_test = 1 ;
uvm_config_db #(user_config) ::set(uvm_top,"uvm_test_top","user_config", config_h ) ;
uvm_config_db #(user_config) ::set(uvm_top,"comp_h","user_config", config_h ) ;
phase.drop_objection(this);
class user_test extends uvm_test ;
`uvm_component_utils(user_test)
`COMP_NEW
user_env env ;
`uvm_info(get_name,$sformatf("In build_phase of %0s",get_full_name()),UVM_NONE)
env = user_env::type_id::create("env",this);
uvm_config_db#( user_config )::wait_modified(this,"","user_config"); // Same as Starting 3 arguments of set() / get() !!
if ( uvm_config_db#( user_config )::get(this,"","user_config",config_h) )
`uvm_info(get_name(),$sformatf(" Get Successful in %0s",get_full_name()),UVM_NONE)
module TOP ;
class Comp extends uvm_component ;
`uvm_component_utils( Comp )
`COMP_NEW
Comp comp_h ;
comp_h = new("comp_h",null ) ;
run_test("user_test");
I Observe different Output across Simulators ( Licensed ones at work )
SIMULATOR1 Output ::
**UVM_INFO @ 0: reporter [RNTST] Running test user_test...
UVM_INFO @ 0: comp_h [comp_h] In build_phase of comp_h
UVM_INFO @ 0: uvm_test_top [uvm_test_top] In build_phase of uvm_test_top
UVM_INFO @ 0: comp_h [comp_h] Get Successful in comp_h
UVM_FATAL @ 9200: reporter [PH_TIMEOUT] Default timeout of 9200 hit, indicating a probable testbench issue
SIMULATOR2 Output ::
**UVM_INFO @ 0: reporter [RNTST] Running test user_test…
UVM_INFO @ 0: uvm_test_top [uvm_test_top] Get Successful in uvm_test_top
[Q] Shouldn’t both the get() Succeed ?
