Passing interface directly to driver in UVM?
How to pass interface directly to driver without sending them through config_db from top?
In reply to Sv-hustler:
There are probably dozens of other ways. But choosing one way makes your code easier to manage, which is the whole point of UVM.
The way in which we can pass interface into driver without using config object!
config object and config_db are 2 different things. Please explain what you mean.
I use config object to send interface to driver . That is by giving interface to interface instance inside config object and then use it to get in driver .
		in test
if(!uvm_config_db #(virtual ram_if)::get(this,“”,“vif”,wcfg.vif));
uvn_config_db #(mem_env_cfg)::set(this,“*”,“mem_env_cfg”,ecfg);
                   in env
uvm_config_db #(mem_write_cfg)::set(this,“wagent*”,“mem_write_cfg”,ecfg.ewcfg);
                    in driver
if(!uvm_config_db #(mem_write_cfg)::get(this,“”,“mem_write_cfg”,wcfg))
Without using config object to send sequence into driver any other way to pass interface?
Looks a little bit confusing. Where do you set your virtual interface. The recommended way is to do this in the toplevel module.
Using a config object is one way to do pass the interface. You can do it directly.
