I have an env configuration file which has different variables. These variables are initialized to a default value inside the configuration file. However I would like to override the default values from the command line. How do I do this? In case no command line values are passed, then the default values must remain. I found suggestions on using uvm_cmdline_processor, but am not clear on its usage.
Any thoughts on this? Thanks!
In reply to tpan:
Can you specify is not clear to you? Have you tried creating an simple example,
HTH,
-R
In reply to tpan:
You can use the pre-defined commandline commands like this:
+uvm_set_config_int=/.mon/,par,9
Or you can specify your own switches.
Thanks chr_sue. I wasn’t aware of uvm_set_config. I will explore its usage and give it a try.
