Hi all,
I’m struggling with parametrized virtual interfaces… :(
I want to use the same parametrized interface (traffic_interface) to different, but same type, agents (traffic_driver for example).
Here an example of my traffic interface:
interface traffic_if #(int data_width = 32)
(input wire clk, reset_n);
logic[data_width-1:0] data_1;
logic[data_width-1:0] data_2;
logic data_en;
endinterface
I tried also with the abstract class (taken from this paper “http://verificationhorizons.verificationacademy.com/volume-7_issue-3/articles/stream/polymorphic-interfaces-an-alternative-for-systemverilog-interfaces_vh-v7-i3.pdf”), but set_config_object is deprecated in UVM 1.2; so I have to use uvm_config_db().
If I try with this code
uvm_config_db#(virtual traffic_if#(.data_width (data_width))::set(uvm_root::get(), "", “dut_traffic_if”, dut_traffic_if.get_concrete_traffic_if());*
the parametrized interface problem still remains.
Have anyone got any ideas?
Thanks to all
