I have come across a lot of statements related to parameterized classes that they should be avoided.
We know the flexibility parameters bring for RTL logic.
I am not sure why this is discouraged in UVM testbench. I understand that it creates a lot of verbose code and is probably prone to error but that is no reason not to use it given the advantage it brings.
I see the following reasons where parameters are really powerful.
- I have an agent which can be instantiated multiple times and each instance can have different bus widths corresponding to DUT interfaces
- I am developing an agent and design team is not in a position to fix the bus size. It might be 128 bits today but can change to 256 bits later
So, the capture buffer in the sequence_items need to be properly parameterized. Once I do this, the sequence_items where they are used also need to be parameterized. For example, in drivers, monitors. Once driver/monitors are parameterized, the agent too need to be parameterized and hence the environment too.
I would like to hear comments why parameters are discouraged given the advantage they bring and if they need to be avoided, are there safer ways to implement?
In reply to verif_learner:
Hello,
Probably Dave will answer this with a more comprehensive explanation, but the main problem you face with parameters is that each agent with a different parameter represents a specialisation, then you face problems for example when casting or using configdb for example the following code will be illegal
function build_phase();
agent_m=new[2];
agent_m[0]=agent#(32)::type_id::create("agent", this)
agent_m[1]=agent#(64)::type_id::create("agent", this)
I previous example you cannot store these agents in a single array since each specialization is a unique type thus generating issues in maintaining the code and extending it.
Probably there are more good reasons lets wait for Dave’s response :)
HTH,
-Ronald
In reply to rgarcia07:
Hello,
agent_m=new[2];
HTH,
-Ronald
so, what is the solution?
There is no way one can design IP blocks without parameters.
I assume the same would be the case with UVM also.
There are 3 ways to deal with oarameters:
(1) storing your parameters in a common package which i specific for each application
(29 using parameterized classes
(3) holding your parameters in the config_db (setting from test)
Depending on your actual requirements you can chosse on of these options.
