I am trying to override parameters to agent but seeing compilation error stating that you can not override 64 bits with 128 bits.
what can be the issue ? Am I missing something? Thanks !
My piece of code -
parameter [31:0][31:0] FIFO_DEPTH = {32’d4, 32’d8, 32’d10, 32’d16};
parameter [31:0][31:0] DATA_WIDTH = {32’d16, 32’d24, 32’d32, 32’d48};
class mst_agent#(parameter MASTER_FIFO_DEPTH = {32’d4, 32’d8 },parameter MASTER_DATA_WIDTH = {32’d16, 32’d24}) extends uvm_agent;
class base_testbench extends uvm_component;
mst_agent#(.MASTER_FIFO_DEPTH(FIFO_DEPTH),.MASTER_DATA_WIDTH(DATA_WIDTH)) mst_agt;
*E,TYCMPAT (base_testbench.sv,81|150): assignment operator type check failed (expecting datatype compatible with ‘class vip_pkg::_mst_agent#(.MASTER_FIFO_DEPTH(128’h00000004000000080000000a00000010),.MASTER_DATA_WIDTH(128’h00000010000000180000002000000030))’ but found ‘class vip_pkg::mst_agent#(.MASTER_FIFO_DEPTH(64’h0000000400000008),.MASTER_DATA_WIDTH(64’h0000001000000018))’ instead).
