Packet generating
I’m generating one packet in driver this
	 @(posedge vif.clk)
	  vif.source_cb.sop   <= 1;
	  vif.source_cb.data  <= trans.data;
	  vif.source_cb.valid <= 1;
	  vif.source_cb.eop   <= 1;
And I repeated this packet 20 times inside sequence
virtual task body();
    trans = a_sequence_item::type_id::create("trans");
    repeat(20) begin
	  `uvm_info(get_type_name(), "Executing sequence", UVM_LOW)
       start_item(trans);
       assert(trans.randomize());
       finish_item(trans);
	   //`uvm_do(trans)
In reply to UvmSv:
Then you have to instruct your sequence to do that explicitly using constraints.
assert(trans.randomize()with {sop == 1; eop == 0;});
assert(trans.randomize()with {sop == 0; eop == 0;});
assert(trans.randomize()with {sop == 0; eop == 1;});
This way…
In reply to UvmSv:
Yes using inline constraints.
