Hello Here is my sample code, for usage of PACKAGES.
Facing a query, while accessing an element from PackageP1, which is imported in PackageP2,
Can you please help me with below code.
package p1;
integer a = 40;
integer b = 30;
integer c = 20;
integer d = 10;
endpackage
package p2;
int a = 33; // IF i redeclare int A, then i can use in below module
import p1::*;
task f1;
$display("B::%0d",b);
$display("D::%0d",d);
int c = 150;
int b; // This gives error, "Identifier "b" previously imported from package p1"
endpackage
import p2::*;
module simple_package();
$display("A::%0d",a);
f1();
// $display("B::%0d",b); // This display gives error "Identifier "d" has not been declared yet.
$display("C::%0d",c);
// $display("D::%0d",d); // This display gives error "Identifier "d" has not been declared yet.
You will need to export p1::* inside package p2. As per LRM:
By default, declarations imported into a package are not visible by way of subsequent imports of that package. Package export declarations allow a package to specify that imported declarations are to be made visible in subsequent imports.
So in your code, try:
package p2;
import p1::*;
export p1::*;
task f1;
int c = 150;
endpackage
If variable ‘integer a’ declared in package p1 need to be accessed from module sample_package,
it can be done using scope resolution operator :: without re declaring it again in package p2.
$display(“A::%0d”,p1::a);
