Overriding uvm_transaction with other different uvm_transaction
I would like to pass two different transactions with in a single put port like the following;
class componentA extends uvm_component;
uvm_blocking_put_port#(trans1) item_port;
trans1 item;
item_port.put(item);
I would like to override trans1 to trans2(completely different one). Can anybody suggest me; Is there any way to do it?
thanks,
mahee.
Provided trans2 inherits from trans1, then you can do this in any case as a result of polymorphism - i.e. you can send both trans1 and trans2 types via the port.
You can also do a UVM factory type override for trans2 with trans1.
