How to override normal driver with error driver parallely
while driving normal driver with in some delay,we have to drive Error driver
Any method to do this
In reply to shiva kumar:
How to do this is very specific to your design.
Generally, you use the factory to override your driver class with an error_driver class, and then override one of the driver’s methods. Inside that method, you need to make a decision amour what and when to introduce an error.
class driver extends uvm_driver;
`uvm_component_utils(driver)
forever (@posedge vif.clk) begin
do_a();
do_b();
virtual task do_a();
class error_driver extends driver;
`uvm_component_utils(error_driver)
task do_a();
if(error_condition)
... // do some error
else
super.do_A();
If driver is VIP we cannot do modifications to Base class driver.
can we use delays in run phase and change override method back to normal driver from error driver
You can still do as I suggested, but only with virtual methods in the original base class.
