In reply to MayurKubavat:
Quote:
In reply to verif_learner:
However I would like to know other practices that an user follows when creating testbench either keeping re-usability in mind or for ease of debug!
Another one in OOPS concept or design pattern is, strategy pattern.
Here is what I have digested after reading design patterns.
If a functional class has to be implemented then cleanly separate out interface and the core function/algorithm. Now, abstract out the interface so that is it not rightly coupled with core function/algorithm. While doing this, think if algorithm A is replaced with algorithm B, would the classes interfacing with this class remain unchanged.
Now, later, if you have to replace Algo A with B then classes interfacing this class should ideally survive. However, if interface was tightly couple with core function, it is almost likely that when Algo A is replaced with Algo B, one would invariably touch the interfacing classes.
As a trivial example, if I want a class to create IP packets, I can have the following API calls:
1) select type of IP packet
2) prepare IP header
3) prepare IP data
4) optionally corrupt IP packet etc.
But later, if I change IP packet with something else, the changes could be needed in the interfacing classes. So, instad of the above APIs, I now name then as follows
1) select layer 3 packet type
2) prepare header
3) prepare payload
Now, the chances of changes in interfacing classes would be minimum if not zero.
