I wrote this code for “Connecting Env to DUT” class under Basic UVM course.
I am getting a NULL pointer deference error from the Env File pasted below. Basically, when i tried to drive a value on the virtual Interface, i am getting a NULL pointer error. Not sure where i need to allocate memory for the interface? Please help!
File: ./my_env.svh, line = 20, pos = 10
Scope: worklib.my_pkg::my_env@1897_1.run_phase
DUT Interface__ —> dut_if.sv
1 interface dut_if;
2
3 logic clock, reset;
4 logic data;
5
6 endinterface
Env File__ —> my_env.svh
1 class my_env extends uvm_env;
2
3 `uvm_component_utils(my_env)
4
5 //my_driver my_driver_h;
6 virtual interface dut_if dut_vif;
7
8 function new(string name, uvm_component parent);
9 super.new(name, parent);
10 endfunction
11
12 function void build_phase(uvm_phase phase);
13 super.build_phase(phase);
14 //my_driver_h = my_driver::type_id::create("my_driver_h", this);
15 endfunction
16
17 task run_phase(uvm_phase phase);
18 phase.raise_objection(this);
19
20 dut_vif.data = 1;
21 #10 dut_vif.data = 0;
22 #10 dut_vif.data = 1;
23 #10;
24
25 phase.drop_objection(this);
26
27 endtask-
28
29 endclass : my_env
Test top__
1 class my_test extends uvm_test;
2
3 `uvm_component_utils(my_test)
4
5 my_env my_env_h;
7
10
11 my_env_h = my_env::type_id::create("my_env_h", this);
12
13 endfunction
14
15 function void build_phase(uvm_phase phase);
16 super.build_phase(phase);
17
18 if(!uvm_config_db#(virtual dut_if)::get(this, "", "dut_vif", dut_vif))
19 `uvm_fatal(get_type_name(), "dut_if has not been instantiated")
20 ----
21 uvm_config_db#(virtual dut_if)::set(this, "*", "dut_vif", dut_vif);
22 endfunction
23
24 endclass : my_test
Top Module__
1 module top;
2
3 import uvm_pkg::*;
4 import my_pkg::*;
5
6 dut_if dut_if1();
7
8 dut dut_inst(._if(dut_if1));
9
10 initial-
11 begin
12 uvm_config_db#(virtual dut_if)::set(null, "uvm_test_top", "dut_vif", dut_if1);
13 run_test("my_test");
14 end
15
16 endmodule : top
DUT module (Empty)__
1 module dut(dut_if _if);
2
3
4 endmodule : dut
