I’m trying to write a function that registers an item with the factory than does does some basic operations to that item. The problem I’m having is that when I try to execute this code I get a null item error.
An example excerpt of the code I’d like to have would be:
modified_sequence_item example_msg_item
function new (string name = ex_sequence);
create_message(example_msg_item, "example_msg_item", 32'hDEADBEEF);
function create_message(modified_sequence_item msg_item, string msg_name, bit[31:0] data);
msg_item = modified_sequence_item::type_id::create(msg_name);
msg_item.data_field = data;
Unfortunately, this doesn’t work. I get the following error:
UVM_FATAL @ 5710: reporter [NullITM] attempting to start a null item from sequence ‘main’
However the following code does work:
example_msg_item = modified_sequence_item::type_id_create("example_msg_item");
example_msg_item.data_field = 32'hDEADBEEF;
Looking at these too bits of code to me they are nearly identical aside from the actions being nested inside a function in the first bit of code. This leads me to believe the issue it is most likely an issue with passing data being the functions. Data scope is another possibility but as the modified sequence item is declared outside of either function I find that less likely.
Does anyone have any recommendations on how I could modify the first code example so that it does not have a null item error when run?
