Need Help in Casting in `uvm_info
my requirement is as below:
class my_sequence extends uvm_sequence ;
    //factory registration
   // function new ()
    task body () ;
     cntr_read (counter1)
 task cntr_read ( reg counter1 )
      counter1.read(//arguments );
      `uvm_info (get_full_name(), $sformatf( "counter %0s value is %0d", counter1, value),OVM_LOW )
In the above code, although counter1 is of reg type, I need to display the counter name as “counter1”. Here it displays either H or decimal value if I use %0h or %0d in place of %0s.
I tried to do $cast, it gave runtime Dynamic Cast Failure.
Any help? I am stuck.
Best Regards,
Mahesh
In reply to MaheshBabu:
counter1 is a uvm_object with several data fields. Using the object name for displaying the name will not work. But the uvm_reg provides you with a convinient function to display the name: get_name().
Thanks for the reply Mr.chr_sue !
But if I use get_name in place of get_full_name , I ended up in compilation error which says- “%0s” is not a valid type to use.
Regards,
Mahesh
I did not say you should replace get_full_name() by get_name.
You should do
`uvm_info (get_type_name(), $sformatf( “%0s value is %0d”, counter1.get_name, value),UVM_LOW )
