hi,i am currently doing ahb based DMA. in my design i have total 48 registers and each register will have fileds and total i think 400 fields are there manually not possible to implement each register inside ral model if you design all register inside ral it will take atleast 10k lines to do. if any one know how to access all register in ral model in simple way?
In reply to VARIKELA RAKESH:
Your best bet is to automate. Have a flow that generates the RAL classes and fields for these regieters and their respecive fields.
The register names and fields will have to be documented somewhere. You may want to look into writing a script that uses this register documentation / programming guide to generate the desired RAL code.
Of course, it’s hard for me to comment if automation will work for your case without looking at the source code, but, your question definitely looks like a case for automation.
The EDA providers are offering there own RAL generators to generate the RAL model automatically.
Here you can find a generator of another company
docs.opentitan.org/hw/dv/tools/ralgen/README/
Please do not genearte the RAL model manually. This might result in tons of errors.
