Hi All,
We were exploring lock/grab feature of uvm_sequencer on UVM-1.2 using below code:
class instruction extends uvm_sequence_item;
typedef enum {PUSH_A,PUSH_B,ADD,SUB,MUL,DIV,POP_C} inst_t;
rand inst_t inst;
`uvm_object_utils_begin(instruction)
`uvm_field_enum(inst_t,inst, UVM_ALL_ON)
`uvm_object_utils_end
function new (string name = "instruction");
class instruction_sequencer extends uvm_sequencer #(instruction);
`uvm_update_sequence_lib_and_item(instruction)
`uvm_sequencer_utils(instruction_sequencer)
class seq_a extends uvm_sequence #(instruction);
instruction req;
function new(string name="seq_a");
`uvm_sequence_utils(seq_a, instruction_sequencer)
virtual task body();
repeat(2) begin
`uvm_do_with(req, { inst == PUSH_A; });
class seq_b extends uvm_sequence #(instruction);
instruction req;
function new(string name="seq_b");
`uvm_sequence_utils(seq_b, instruction_sequencer)
lock();
repeat(2) begin
`uvm_do_with(req, { inst == PUSH_B; });
unlock();
class seq_c extends uvm_sequence #(instruction);
instruction req;
function new(string name="seq_c");
`uvm_sequence_utils(seq_c, instruction_sequencer)
lock();
repeat(2) begin
`uvm_do_with(req, { inst == POP_C; });
unlock();
class parallel_sequence extends uvm_sequence #(instruction);
seq_a s_a;
seq_b s_b;
seq_c s_c;
instruction_sequencer m_sqr;
function new(string name="parallel_sequence");
s_a = seq_a :: type_id :: create("s_a");
s_b = seq_b :: type_id :: create("s_b");
s_c = seq_c :: type_id :: create("s_c");
`uvm_sequence_utils(parallel_sequence, instruction_sequencer)
s_a.start(m_sqr);
s_b.start(m_sqr);
s_c.start(m_sqr);
join
class instruction_driver extends uvm_driver #(instruction);
// Provide implementations of virtual methods such as get_type_name and create
`uvm_component_utils(instruction_driver)
// Constructor
$display("0: Driving Instruction ",$time,req.inst.name());
#10;
seq_item_port.item_done();
class test extends uvm_test;
instruction_sequencer sequencer;
instruction_driver driver;
parallel_sequence par_seq;
`uvm_component_utils(test)
function new (string name = "", uvm_component parent=null);
endfunction: new
sequencer = instruction_sequencer::type_id::create("sequencer", this);
driver = instruction_driver::type_id::create("driver", this);
endfunction: build_phase
super.connect_phase(phase);
endfunction: connect_phase
super.run_phase(phase);
par_seq = parallel_sequence::type_id::create("par_seq");
par_seq.m_sqr = sequencer;
phase.raise_objection(this);
par_seq.start(sequencer);
phase.drop_objection(this);
endtask: run_phase
endclass: test
module tb();
initial
run_test("test");
endmodule: tb
Here, our expected output was:
0 PUSH_A
10 PUSH_B
20 PUSH_B
30 POP_C
40 POP_C
50 PUSH_A
But we're getting below output:
0 PUSH_A
Here it is displaying only first fetch from the driver, rest all requests are getting stuck in sequencer queue and that's the reason we're getting timeout error from UVM. So is this behavior expected?
Thanks and Regards,
Mitesh Patel
