Multiple drivers in always_latch
I have following Code ::
module dummy_dut(input value1, index1);
reg [7:0] data[100];
logic [7:0] value, index ;
always_latch  begin
 // Some Logic Here
 data[index] <= value;
module top;
import uvm_pkg::* ;
`include "uvm_macros.svh"
dummy_dut dut1(value, index);
 run_test("dummy_stimulus");
// On Uncommenting below I get Error ::
// Variable '/top/dut1/data[10]' "driven in a combinational block, may not be driven by any other process."
//initial begin
// data[10] = 5;
//end
class dummy_stimulus extends uvm_test;
 `uvm_component_utils(dummy_stimulus)
function new (string name ="stimulus",uvm_component parent =null);
 super.new(name,parent);
   top.dut1.data[5] = 10 ; // Works , but How ??
   $display("DATA[%0d]=%0d",5,top.dut1.data[5]);
   #10;
   $display("inside main_phase");
My confusion is , since the build_phase() of the test is a seperate process , shouldn’t this be an error too ??
In reply to Have_A_Doubt:
I believe this is a tool specific issue. Some tools are only enforcing the multiple driver rule within RTL code. This Mentor sponsored public forum is not for discussing tool specific issues. Please contact your tool vendor directly for support.
