Hi ,
I am doing simple example in UVM with three writes followed by the reads.Simulated in EDA
i am not able to sync Scoreboard and Monitor,help me in analzying the code.
~Taahir
Hi ,
~Taahir
In reply to syed taahir ahmed:
Taahir,
What’s happening is your “write” monitor is storing the same transaction handle in every portion of the FIFO, because you only create a single handle that gets reused. Monitors need to “create” a new transaction, everytime.
In reply to bmorris:
HI Bmorris,
Thanks much…I was in a impression that each time the monitor will add a data item to the fifo.
Ok now i understand each transaction should have unique handle.
~Taahir
