Hi All,
I am struct at one place. I am trying to implement RAL environment. I don’t have much knowledge of RAL. I am getting below error:-
UVM_ERROR /proj/eda/cadence/incisive/151/15.10.011/tools.lnx86/methodology/UVM/CDNS-1.1d/sv/src/reg/uvm_reg.svh(2892) @ 299616000203fs: reporter [RegModel] Register “fpgadp_regs.DP_DMA_HOST_CTL1” value read from DUT (0x0000000080004000) does not match mirrored value (0x00000000c0004000)
UVM_INFO /proj/eda/cadence/incisive/151/15.10.011/tools.lnx86/methodology/UVM/CDNS-1.1d/sv/src/reg/uvm_reg.svh(2911) @ 299616000203fs: reporter [RegModel] Field done (fpgadp_regs.DP_DMA_HOST_CTL1[30:30]) mismatch read=1’h0 mirrored=1’h1
UVM_INFO @ 299616000203fs: reporter [RegModel] Read register via map fpgadp_regs.FPGA_PCIE_MAP_DP: fpgadp_regs.DP_DMA_HOST_CTL1=80004000
Here Mirror value (register value inside the RAL model) is not going to update after reading from DUT.
So, What could be the problem?? Please guide me.
KAPIL
