Hi
I am seeing Member reference resolution error(line num 52) related to uvm_analysis_imp_decl.(please check the line uvm_analysis_imp_dec)
I connected monitor analysis port to another component analysis export .
Can anyone plesae help on this?
class transaction #(parameter LENGTH=10) extends uvm_sequence_item;
rand bit a;
`uvm_object_param_utils_begin(transaction#(LENGTH))
`uvm_field_int(a,UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="transaction");
class monitor#(parameter LENGTH=5) extends uvm_monitor#(transaction#(LENGTH));
`uvm_component_param_utils(monitor#(LENGTH))
transaction#(LENGTH) tr;
uvm_analysis_port#(transaction#(LENGTH)) analysis_port;
function new(string name="monitor",uvm_component parent);
super.new(name,parent);
tr=new("mahen");
$display("mahen");
analysis_port.write(tr);
linenum 52:`uvm_analysis_imp_decl(_mon)
class model#(parameter LENGTH=5) extends uvm_component#(transaction#(LENGTH));
`uvm_component_param_utils(model#(LENGTH))
uvm_analysis_imp_mon#(transaction#(LENGTH)) mon_export;
mon_export=new("mon_export",this);
function write_mon(transaction#(LENGTH) trans);
$display("in_monitor");
class env#(parameter LENGTH=5) extends uvm_component#(transaction#(LENGTH));
`uvm_component_param_utils(env#(LENGTH))
model#(LENGTH) md;
monitor#(LENGTH) mon;
function build_phase(uvm_phase phase);
md=model#(LENGTH)::type_id::create("model",this);
mon=monitor#(LENGTH)::type_id::create("mon",this);
function connect_phase(uvm_phase phase);
mon.analysis_port.connect(md.mon_export);
class test#(parameter LENGTH=5) extends uvm_component#(transaction#(LENGTH));
//`uvm_component_param_utils(test#(LENGTH))
typedef uvm_component_registry#(test#(LENGTH),"test") type_id ;
env#(LENGTH) en;
en=env#(LENGTH)::type_id::create("env",this);
#10;
module top;
parameter LENGTH=10;
typedef test#(LENGTH) delay_test;
initial
run_test();
TimeScale is 1 ns / 1 ns
Error-[MRRE] Member reference resolution error
testbench.sv, 52
Member operator “.” cannot be used on object of type int.
Expression: m_imp
Source info: m_imp.write_mon
praneeth
