the test runs default sequence from the main_phase and log file prints the below message
"reporter [TEST_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase "
How can I stop print the above message in log file when the sequence runs from the main_phase instead of run_phase ?
Note: Whenever default sequence runs from the run_phase it doesn’t print the above message
Hi kddholak,
Could you please clarify regarding the note you have mentioned ? As I tried both the cases(running the default sequence in both run_phase and main_phase, but I could see the same message is getting displayed in both the cases.
Can you explain why you want to suppress this message? This is a very useful message that lets you know when all of your test stimulus is completed and the environment is ensuring that everything is correct.
