Hi UVM forum,
I have a layered sequencers architecture one:many.
meaning that I have few lower sequences with a pointer to one upper sequencer.
in the sequences I have the following code.
class lower_seq_A extends uvm_sequence #(my_seq_item);
upper_sequencer upper_seqr;
task body();
upper_seqr.get(req_up);
start_item(req_lo);
finish_item(req_lo);
endclass : lower_seq_A
There are scenarios that all the sequences request item from the upper sequencer at the same simulation time.
so now new I have race condition, if one of the sequences get the request, the upper sequencer clean the fifo, and the other sequences get different items. in my application it is important that if few sequences request item at the same simulation time they must get the same item.
How can I solve this issue?
In reply to shimonc:
Unfortunately you do not show how your UVM structure looks like. But I guess you have one-to-one connections as always on the sequencer driving side. If you have more than one low level sequencers, you have to make a copy of the actual seq_item and distribute it the all your low-level sequencers. This should solve your issue.
Hi chr sue
My UVM structure is one:many. one upper sequencer and many lower sequencers.
I did some experiments and I found out that for my application is best to have one:one layered sequencer connection and than from the lower sequence send the seq_item to all other sequences.
following is part of the code.
the one:one sequence structure
virtual task body();
uvm_event_pool ev_pool = uvm_event_pool::get_global_pool();
uvm_event sync_event = ev_pool.get("sync_event");
m_rtp_mng_sequencer.get(m_rtp_mng_seq_item);
sync_event.trigger(m_rtp_util_seq_item);
one of the receiving sequences
sync_event.wait_trigger();
$cast(m_rtp_util_seq_item, sync_event.get_trigger_data());
// Start handshake with agent sequencer
start_item(m_rtp_ind_seq_item);
finish_item(m_rtp_ind_seq_item);
