Is it recommemded to use delay in between start_item and finish_item?
is it recommemded to use delay in between start_item and finish_item in task body of sequence?
In reply to lalithjithan:
The UVM does not allow it.
Finish_item must be called after start_item with no delays or delta-cycles.
