uvm_config_db#(virtual ei_can_interface)::set(null,“uvm_test_top.env.agent[0].",“vif”,pif[0]);
uvm_config_db#(virtual ei_can_interface)::set(null,"uvm_test_top.env.agent[1].”,“vif”,pif[1]);
uvm_config_db#(virtual ei_can_interface)::set(null,“uvm_test_top.env.agent[2].*”,“vif”,pif[2]);
In reply to d_g:
Yes. ;-)
Since the second argument to set() is a string, you can use $sformatf to format the string.
for (int i = 0; i < 3; i++)
$sformatf("uvm_test_top.env.agent[%0d'.*",i),"vif",pif[i]);
