I’m a UVM Register model novice and before I attempt to implement I have a query regarding accessing register model mirrored values from elsewhere in the testbench, particularly from with a reference model.
My DUT contains a number of registers containing set-up data. This set-up data is also needed within a reference model of the device function. I think I have a good idea of how I can write the set-up data to the DUT via the RAL and also set the associated mirrored values via a predictor/adapter block.
What I’m not so sure about is if/how I can access the set-up data stored within the register model mirrored values directly from a reference model. Is this possible or does the reference model need to store its own version of the data?
If it is possible, what is the recommended method of accessing the set-up data?
The output of the reference model needs to be stored as a mirrored value in the register model. Am I correct in thinking that I just need to pass the reference model output as a transaction through predictor and adapter blocks in order to update the register model?
Tony.
