Issue with UVM Driver to send request transactions on parallel bus
I read the blog post on UVM Driver models and am trying to implement a driver for the case (simplified) below.
On the interface, there is an address channel & a Data channel.
On the address bus, four addresses are sent back to back.
After 4 address requests are placed, at the end of A4 Data bytes are placed on the data bus in succession
A1 A2 A3 A4
xx xx xx xx D1 D2 D3 D4
To realize this I used fork_join none blocks in the run_phase of the driver which has three threads running.
  1. Thread 1 will collect sequence items from the sequence and pushes them on a two queues
  2. Thread 2 drives address on VIF from one queue
  3. Thread 3 drives data from another queue after 3 cycles delay.
When simulated I see simulation terminates abruptly with no clear message ( on edaplayground). Could someone point the flaw in my implementation?
UVM_INFO dut_parallel_driver.sv(45) @ 3: uvm_test_top.env.agent.driver [t_driver] Outof Reset
./run.sh: line 8: 608 Killed ./simv +vcs+lic+wait ‘+UVM_TESTNAME=uvmtest’ ‘+UVM_VERBOSITY=UVM_MEDIUM’
Exit code expected: 0, received: 1
class t_driver extends uvm_driver #(packet);
  `uvm_component_utils(t_driver)
  virtual p_intf.tb_mp vif_tb;
  packet pa[$];
  packet pd[$];
    super.new(name,parent);
    if(!(uvm_config_db #(virtual p_intf.tb_mp)::get(this,"","virtual_intf", vif_tb)))       		begin
      `uvm_error(this.get_full_name,"Virtual Interface not set from agent");
   packet req;
    if(vif_tb.reset)
          `uvm_info(get_type_name(),$sformatf("Inside DUT Reset"),UVM_LOW);
          vif_tb.cb.valid    <= 0;
          wait(!vif_tb.reset);
 forever
         `uvm_info(get_type_name(),$sformatf("Fetching next request"),UVM_LOW);
        pa.push_back(req);
        pd.push_back(req);
         seq_item_port.item_done(req);
         drive_address(pa);
         drive_data(pd);
    join_none
virtual  task automatic drive_address(packet req[$]);
    packet pkt_ad;
    //wait until there are packets in Queue
    while (req.size() == 0)
              @(vif_tb.cb);
    `uvm_info(get_type_name(),$sformatf("Addr Queue Size = %0x", req.size()),UVM_LOW);
    while (req.size()!=0)
    	pkt_ad = req.pop_front();
    	`uvm_info(get_type_name(),$sformatf("Executing Addr = %0x", pkt_ad.addr),UVM_LOW);
          vif_tb.cb.addr  <= pkt_ad.addr;
          vif_tb.cb.valid <= 1'b1;
          @(vif_tb.cb);
           vif_tb.cb.valid <= 1'b0;
 virtual task automatic drive_data(packet req_d[$]);
        packet pkt_dat;
    while (req_d.size() == 0)
              @(vif_tb.cb);
    `uvm_info(get_type_name(),$sformatf("Data Queue Size = %0x", req_d.size()),UVM_LOW);
    while(req_d.size()!=0)
    pkt_dat = req_d.pop_front();
    `uvm_info(get_type_name(),$sformatf("Executing Data = %0x", pkt_dat.data),UVM_LOW);
    repeat(3) @(vif_tb.cb);
                 vif_tb.cb.data <= pkt_dat.data;
In reply to Nagarjuna Chary:
It would really help to show a complete example showing the behavior you are seeing.
Your driver is taking all of the sequence_items from the sequencer and storing them in a queue in the driver. I’m guessing that when your sequence has completed generating all of the sequence_items, your test ends immediately and the driver never has a chance to actually drive any transactions.
In reply to cgales:
To prevent the test not to exit I added a dummy delay in the sequence class ( which should otherwise wait until it got all the responses through the scoreboard etc). Let me know if providing the link to code on EDAPlayground is fine.
class t_sequence extends uvm_sequence #(packet);
  `uvm_object_utils(t_sequence)
     int num_trans;
  function new(string name="my_sequence");
  virtual task body();
    packet pkt;
    $display("In Body Task");
    if(!(uvm_config_db#(int)::get(null,this.get_full_name,"req_count",num_trans)))
      `uvm_warning(get_type_name(),"Transaction count not specified in Test Top")
        num_trans =10;
    else `uvm_info(this.get_full_name,$sformatf("Running sequence with %d requests",num_trans), UVM_HIGH);
    pkt = packet::type_id::create("pkt");
    use_response_handler(1); // Enable Response Handler
    for(int i=0;i<num_trans;i++)
       `uvm_info(this.get_full_name,$sformatf("Sending request number %d",count), UVM_HIGH);
        start_item(pkt);
        assert(pkt.randomize());
        `uvm_info(get_type_name,$sformatf("Addr=%0x Data=%0x",pkt.addr, pkt.data), UVM_MEDIUM);
        finish_item(pkt);
    #100;
    `uvm_info(this.get_full_name,$sformatf("Idle waiting"), UVM_MEDIUM);
    wait(count == num_trans);
   function void response_handler(uvm_sequence_item response);
    count++;
     `uvm_info(get_type_name,$sformatf("Responses Received=%0x",count), UVM_MEDIUM);
   endfunction: response_handler
Per the blog post I referenced, posting a link to your example on EDA Playground is ideal.
In reply to cgales:
Here is the link. file name being discussed about is “dut_parallel_driver.sv”
You have some issues in the parallel driver where you are trying to fork processes when you receive packets. The ideal implementation is to have the address/data processes running all the time and waiting for transactions to appear in the queue.
You can see the changes I made here.
In reply to cgales:
Thanks much cgales! I was struggling to create the parallel threads which would get requests from the sequence class & drive the dut and was focusing on packing them in a single fork/forever construct. Thanks also for the usage of ‘phase_ready_to_end’. I was under the assumption that such a ‘wait’ is only possible with a scoreboard.
