Issue with uvm db configuration
Hello everyone,
i’m new to UVM, i’m trying to write a testbench for a D-FlipFlop on Questa .
i tried to follow steps as described in the tuto but i always get an error message telling me that my no virtual interface was found.
I’m stuck with this.
can somebody help me? i will be grateful.
In reply to AurelienTse:
It will be very difficult to answer your question without showing your implementation. kindly paste your relevant code, it will resolve your issue easily.
Hello everyone,
You have to pass the virtual interface to the config_db from the toplevel module. You might miss this.
config_db needs always a pair of set/get.
AurelienTse,
It would be good if you can share the ERROR message.
I guess one of the below could be a reason :
  1. The virtual interface that you have set at tb_top is not properly get in the driver/monitor. The field names should match .
  2. The get part needs be in the build_phase of driver/monitor.
~Pranoy
