Need help.
I am facing an issue in setting up hdl path.
Using back door access,
this is the access hdl path: top.dut_i.x_i.y_i.z_i.reg
Here top - Top Module
dut_i - dut Module instance name
x_i - x Module instantiated in dut module
y_i - y Module instantiated in x module
z_i - z Module instantiated inside a
generate
block in y module
when I ran the simulation I am getting this error:
" UVM_ERROR: set: unable to locate hdl path (top.dut_i.x_i.y_i.z_i.reg)
Either the name is incorrect, or you may not have PLI/ACC visibility to that name "
But in other way I have tried to access these below paths all are working fine
- hdl access path: top.dut_i.x_i.y_i.reg_x
- hdl access path: top.dut_i.x_i.reg_y
- hdl access path: top.dut_i.reg_z
I think the problem is with the RAL in accessing instance path through
generate
block.
How to resolve this?
Thanks in advance
Rajashekhar
