Hi
I am new to UVM. I actually work on a uvm test and I have to write an interface that will link some DUT signals with my test. But I didn’t find examples for this case, only example with driver and monitor. I obtained the same error, my interface is not set. Following my code:
interface int_if(input clk);
logic my signal;
endinterface
class int_if_hand_c;
virtual int_if vif;
int_if_hand_c int_if_hand;
virtual int_if vif;
// Constructor:
function build_phase(uvm_phase);
int unsigned success;
success = uvm_config_db #(virtual int_if)::get(this, "", "vif", vif);
if (!success) begin `uvm_fatal("CFG","Virtual interface is not set"); end
success = uvm_config_db #(int_if_hand_c)::get(this, "int_if_hand", "", int_if_hand);
if (!success) begin `uvm_fatal("CFG","int_if_hand is not set"); end
uvm_config_db #(virtual interface int_if)::set(this, "", "" ,int_if_hand.vif);
What did I do wrong? Thanks
Juliette
Hi Julette,
There are two points to get the interface in the test case:
The interface must be set in the general way in the tb_top in UVM, so over there set the interface as uvm_config_db #(virtual int_if):: set (uvm_root::get, “*”, “intf_hand”, int_if_hand); , this statement does you to get the interface to both higher and lower components in the VE.
Now you can use it directly using get success = uvm_config_db #(virtual int_if)::get(this, “”, “intf_hand”, int_if_hand);
My concern why do you want to set the interface again in the test case build_phase,
I think so that you have already got the interface and could use the same to
drive any signals on to the interface.
uvm_config_db #(virtual interface int_if)::set(this, “”, “” ,int_if_hand.vif); syntax is wrong it should be #(virtual int_if) and set has the following arguments set(context,“instance_path”,“string_name”,variable_name).
Nikhil
In reply to nchakravarthy:
Thanks a lot for your answer.
So I have some questions: I have to set my interface in the tb_top necessarily? I can’t do this in my test? That what I tried to do in fact…
And Where I should configure the clock and the signals from the DUT of my interface?
Juliette
In reply to juliette_29:
In UVM we set the physical interface in the tb_top and we get it in the VE, so where ever you get the interface it points to the physical interface.
you can drive the clock period in any component where you get the interface, there is no need to set the interface again as the virtual interface in your test case, it points to the physical interface. Generally we drive the DUT signals in the driver and the clock configuration can be done in test case or you can drive clock in your tb_top.
Thsnks,
Nikhil
Thanks a lot for your answer!
Hi Julette,
- The interface must be set in the general way in the tb_top in UVM, so over there set the interface as uvm_config_db #(virtual int_if):: set (uvm_root::get, “*”, “intf_hand”, int_if_hand); , this statement does you to get the interface to both higher and lower components in the VE.
- Now you can use it directly using get success = uvm_config_db #(virtual int_if)::get(this, “”, “intf_hand”, int_if_hand);
- My concern why do you want to set the interface again in the test case build_phase,
- uvm_config_db #(virtual interface int_if)::set(this, “”, “” ,int_if_hand.vif); syntax is wrong it should be #(virtual int_if) and set has the following arguments set(context,“instance_path”,“string_name”,variable_name).
Nikhil
what about test cases extended from base test
i done as below but getting error
ex class test_case2 extends base_test;
virtual lbus_if lbus_vif;
//function new
//start of simulation phase
//build phase
$assertoff(lbus_if.cssss);
endclass: test_case2
In reply to DV intern:
It would really help if you posted the error but I’m guessing that $assertoff did not like the virtual interface and wanted to see an actual interface.
Hey Dave, I encounter the above scenario by using disable iff in assertion(in interface file) so that i can control in test cases by interface handle.
but i want to know why it not like Virtual interface ?
in my base test it’s virtual interface, i used that in test cases as $assertoff(lbus_if.cssss);
please suggest how to use vif in $asserton/off
Error: Fatal error (bad handle reference)
The first argument to $assertoff is a numeric level, and the second argument is a scope. A virtual interface variable is not a scope.
I suggest you create a function inside your interface that you can call via a virtual interface handle.
interface bus;
cssss: assert property(....);
function void cssss_off;
$assertoff(0,cssss);
endinterface
Thank you, dave
Hi Dave I have one more doubt, any another way to use the class handle inside the interface?
For example
class config;
bit [9:0] q_value;
interface
task cal;
if(--------)// I NEED TO USE THE CONFIG Q_VALUE INSIDE THE IF STATEMENT
endinterface
Is there any way to access the value inside the interface?
Where is the class object being constructed? You can use the uvm_config_db to set and get the handle.
