I create interface in my tb spy_if_inst to spy on internal signal.
tb code:
module hdl_top_tb;
import top_tb_params_pkg::*;
dragon_top_sim dragon_top
default_clk_gen default_clk_gen
.CLK(default_clk_gen_CLK)
default_reset_gen default_reset_gen
.RESET(default_reset_gen_RESET),
.CLK_IN(default_clk_gen_CLK)
spy_if spy_if_inst();
assign spy_if_inst.done = dragon_top.dragon_design_i.cu_top0_i.cuc_done;
initial
$display("[hdl]done %b:",spy_if_inst.done);
uvm_config_db #(virtual spy_if )::set( null , "*" ,"spy_if_inst", spy_if_inst);
endmodule: hdl_top_tb
interface spy_if;
logic done;
logic busy;
endinterface
i try to use in this interface in component
class generator extends uvm_component;
virtual spy_if spy_if_inst;
`uvm_component_utils(generator)
function new(string name = "generator", uvm_component parent = null);
if(spy_if_inst != null)begin
spy_if_inst.done = 1;
$display("done %b:",spy_if_inst.done);
@(posedge spy_if_inst.done)begin
//// Build Function
if(!uvm_config_db #(virtual spy_if)::get(this, "", "spy_if_inst",this.spy_if_inst))
`uvm_fatal("FATAL MSG", "Configuration Object Not Received Properly");
the connection dont work spy_if_inst is null!
what worng?
In reply to TamarB:
Please explain “dont work”. Does not compile? uvm_config_db returns true, but this.spy_if_inst is still null?
Where is this code?
the code is in func run()
I try to retrieve an instance of the spy_if interface from the configuration database.
The variable found =1
This means that the get function is successful
But the spy_if_inst is still null
What missing in the code?
function void generator::build_phase (uvm_phase phase);
$display("Before get(): spy_if_inst = %p", spy_if_inst);
found = uvm_config_db#(virtual spy_if)::get(null, "", "spy_if_inst", spy_if_inst);
$display("After get(): spy_if_inst = %p", spy_if_inst);
$display("found %b:",found);
In reply to TamarB:
Are you sure you only have one declaration of spy_if_inst in you generator, and non inside your run method?
In reply to TamarB:
Your get call should be
found = uvm_config_db#(virtual spy_if)::get(this, "", "spy_if_inst", spy_if_inst);
@dave_59
Yes I’m sure
@chr_sue
found = uvm_config_db#(virtual spy_if)::get(this, “”, “spy_if_inst”, spy_if_inst);
Still the object remains null
Maybe the connection between top and generator is wrong??
In reply to TamarB:
Could you please use the simulator switch
+UVM_CONFIG_DB_TRACE
to trace the usage of the config_db.
What does this information give me and where?
In reply to TamarB:
It reports you the uvm_config_db entries.
But I believe we are hunting in the wrong place for a non-existing error.
Please ignore the error message from the build_phase and try if you see the virtual interface in the run_phase. It shoule be there.
I was execising one of my basic examples and found the same rror as you did. But I see the virtual interface when running the simulation.
i try to use in run_phase
but i get error
** Fatal: (SIGSEGV) Bad handle or reference.
on this line
$display(“done %b:”,spy_if_inst.done);
while( read_queue.num()>0)begin
read_queue.get(trans);
trans.is_write=0;
trans_queue.put(trans);
In reply to TamarB:
OK, the virtual interface does not exist.
But it’s guessing what we are doing.
Can you share your testbench code personally?
In reply to TamarB:
If think so.
I could have a look tomorrow to your code.
Please send a tar-file to
christoph@christoph-suehnel.de
