Hi All,
I’m getting below error in vcs.
Error-[ICTTFC] Incompatible complex type usage
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the
function. The type of the actual is ‘class
TB_WORK.uvm_pkg::uvm_object_wrapper’, while the type of the formal is ‘class
TB_LIBS_WORK.uvm_pkg::uvm_object_wrapper’. Expression: w_
Source info: this.create_item(w_, this.m_sequencer, “trans”)
the file which has following content
class gahb_mvc_seq extends mvc_sequence;
`uvm_object_utils(gahb_mvc_seq)
rand integer count;
rand qgahb_mvc_trans trans;
function new(string name="gahb_mvc_seq");
super.new();
endfunction : new
task body();
repeat (count) begin
`uvm_do(trans) <--- from this line this error is poping up
endtask : body
I’m not getting what exactly it is showing , Help me how to reslove this error.
